best way to unstick a clutch in a M?
M guy
12-29-2004 04:10:36
Got a M with a frozen clutch. any ideas on how to unstick it?
Later,
Will
brianh
12-29-2004 06:07:20
 Re: best way to unstick a clutch in a M? in reply to M guy, 12-29-2004 04:10:36
If it doesn't have a belly pump, the clutch is simple to get to from underneath. You can screw a couple of bolts in the release holes and pull the plate away from the flywheel that way, or take it apart and clean it up right. Generally they get full of mouse nests, and then, mouse poop, which pretty well gums them up from then on....Brian
Merle Hoppenworth
12-29-2004 05:28:34
I don't know how long it has been stuck but I got one unstuck on a Oliver 1650 some time back. It was left without starting about 1 month. I got it started in gear, let it coast down hill to shift up to high gear, then drove it for about 1/2 hour, then pushed the clutch in and slammed on one brake and it came loose. You may have trouble getting into 5th as of the jump between 4th and 5th. I blammed my success on that I thought the flywheel warmed up and the jolt from one brake broke it loose. Good luck.
