Belly pump on IH H
Greg Cyza
12-29-2004 06:47:24
My belly mounted mower will not stay up. Dealer says the check valve may have a broken spring. Is this easy to get to? Removal of the pump necessary? Any info would be appreciated.
Jim Lockhart
01-03-2005 21:39:54
 Re: Belly pump on IH H in reply to Greg Cyza, 12-29-2004 06:47:24
Greg,what type of belly mower do you have?I am looking for one for the wife's H and don't know what brand or type I need.Thanks
Greg Cyza
01-03-2005 22:10:19
 Jim Lockhart info in reply to Jim Lockhart, 01-03-2005 21:39:54
It's actually a cycle mower. {Don't think I spelled that right. } It's a Kosch brand. I believe they're made or at least were made in Columbus,NE by Kosch Manufacturing.
Jim Lockhart
01-03-2005 22:13:43
 Re: Jim Lockhart info in reply to Greg Cyza, 01-03-2005 22:10:19
BINGO that is exactly what I am looking for.Thanks again man
John M
12-29-2004 12:16:53
What about your oil level,is it ok? Simple checks before tearing into something can save yopu alot of work.
Herb In Tx
12-29-2004 10:16:16
Might try this first. When I first got my super H {early with belly pump} The hydraulics would not hold eiter. But i did notice that they would hold if I held the handle for the lift about a 1/2 inch from the stop where it would normally hold, it would in fact hold there. S i walked out to my 44 H and noticed the support for the control rod was at a slightly different angle. Then I got out my trusty 18 inch pipe wrench and bent the support to where the cylinders woould remain in the position I left them and the pump not be in stroke. Been working fine for more than a year now.
