Order Farmall Cub Parts Online
clutch stuck on a cub
andruw50
12-29-2004 11:29:54
Any advice on how to unstick a clutch on a 58 cub
Kevin (FL)
12-30-2004 07:00:52
 Re: clutch stuck on a cub in reply to andruw50, 12-29-2004 11:29:54
Does the pedal go down but the pressure plate isn't releasing? If it's only been stuck for a short while, the disc might be just stuck to the flywheel or pressure plate with surface rust. If you're working alone, jackup one rear, shift into 1st, use a 2x4 or something to press the clutch all the way down and then turn the raised rear tire back and forth until the clutch lets go. If you have a helper with another tractor, you can pull the tractor with the clutch disengaged and tranny in gear. Be very careful as you know the front ends are very weak and the block casting is "soft"--easy to break the engine mount area. Use rope, not chain and pull gently or tow from rear instead of front. To assist with the job, you can spray some Gunk engine cleaner up into the bell housing, trying to get it to the top of the flywheel and run down onto the clutch/pressure plate and also the clutch fork area too.
All this is said with the assumption that you have no mechanical issue with the clutch fork, throwout bearing etc and that the clutch is just stuck lightly from not using the tractor a few months.
old
12-29-2004 11:47:47
Had that problem on one this summer found that the throw out bearing was bad. In this one its just a hard block of plastic or something like that. Have you looked un in to the tube with the adjustment plate off with someone pushing the clutch down? You maybe able to see whats going on it there if you do.
Gene
12-29-2004 11:40:57
The only sure fired way is to split the tractor. Not much of a job. Takes about 4 hours.
You might try working the tractor. Drive the tractor, depress the clutch then step on the brakes - repeat the process - repeat the process.
Good luck
Gene
