IH-B-250 DIESEL
ALBERT BUCHLER
12-29-2004 15:34:54
Anybody,on type and quantity of hyd. oil for trasmission and hyd. Systeme,for above.And Diagram [photocopy]for Gearbox and Hyd. Systeme, by the way i only use hyd. for 3-point linkage.
Regards Albert.
EricB
12-31-2004 06:08:36
 Re: IH-B-250 DIESEL in reply to ALBERT BUCHLER, 12-29-2004 15:34:54
Albert:
I use any standard heavy Duty Hydraulic oil. I may not be the one to ask since mine was leaking all over the place. I replaced all the fittings and hoses this fall. With the cold weather it seems to be holding well.
Transmission oil, the same. If you are in Canada there is Canadian Tire which has a great range. I look for stuff designed for backhoes etc. I use my 250 for everything from snow blowing, post hole digging, plowing and disking.
Great little machine.
oldtime
12-29-2004 18:32:49
i use engine oil 10w30 i think the book calls for 10 but i use a multigrade works for me
