Super C Fast Hitch Hose Routing
Bud W
12-31-2004 06:30:36
Can anyone tell me how to route the hydraulic hose' from the check valve in front of the seat to the rear hydraulic cylinder? Does the right side ( as you set on the tractor looking forward over the hood )of the the check valve connect to the right side of the cylinder?
Thanks
Brian Schmidt
12-31-2004 17:13:49
 Re: Super C Fast Hitch Hose Routing in reply to Bud W, 12-31-2004 06:30:36
Bud,
On mine the right goes to the right and the left to the left. On dad's his are switched as he likes it that way. On his you push the handle forward to lower instead of raise. I routed mine like the factory. You can do it however you feel comfortable with.
Paul Shuler
12-31-2004 07:16:40
On mine they go through an opening under the seat back to the fast hitch.Not sure if that is what you where asking or not.
BUD W
12-31-2004 08:18:56
 Re: Super C Fast Hitch Hose Routing in reply to Paul Shuler, 12-31-2004 07:16:40
Paul
What I need to know is which hose connects to each side of the cylinder. Does the left hose coming out of the check valve block under the seat connect to the left or right side of the cylinder?
Thanks
Bud
Paul Shuler
12-31-2004 09:01:33
 Re: Super C Fast Hitch Hose Routing in reply to BUD W, 12-31-2004 08:18:56
Oh, I'll have to look at that, I'm not sure right off hand.
