Farmall H wide front steering repair
davos
12-31-2004 11:03:17
I have a widefront H that has mucho play in the steering (1/2)turn almost). I have installed a decent gear on the vertical spindle that the worm drives. However the vertical spindle has about 3/8 inch vertical play. How do you take this out???
Thanks
Geoff NY
12-31-2004 13:21:45
 Re: Farmall H wide front steering repair in reply to davos, 12-31-2004 11:03:17
As a kid, I thought that was "power steering"
Farmer Bob
12-31-2004 11:20:14
Most likely the thrust bearing has worn out.
davos
12-31-2004 13:21:31
 Re: Farmall H wide front steering repair in reply to Farmer Bob, 12-31-2004 11:20:14
Is that on the bottom of the spindle below the yoke/??
Farmer Bob
12-31-2004 18:14:54
 Re: Farmall H wide front steering repair in reply to davos, 12-31-2004 13:21:31
third party image
Here's a picture of where the lower thrust bearing and spacer is located on the H.
davos
01-01-2005 04:17:38
 Re: Farmall H wide front steering repair in reply to Farmer Bob, 12-31-2004 18:14:54
Thanks so much for the help. I hope to get it apart and replace the bearing. Are the wide fronts hard to keep repaired. I noticed mine has some welds on the connecting links.
Thanks again
