Super A won't move
fredmich
12-31-2004 19:07:14
Went to move the the A in the barn when it was very cold and it started right up but when I put it in gear and let the clutch out it would just kill the motor. The gear shift was very sluggish. Also was not able to rock the tractor by pushing on the rear wheels. Could it be stuck in reverse and a forward gear at the same time. Any ideas? Thanks.
fredmich
01-01-2005 08:35:37
 Re: Super A won't move in reply to fredmich, 12-31-2004 19:07:14
Thanks for the responses. It has warmed up some here in Mich. but the tractor is 200 miles north. They all make sense and the next time I'm up north I hope it will be warmer and I'll change the fluids in the spring. Happy New Year.
Dave BN
01-01-2005 06:45:15
I'm betting on water (ice) in the gear oil also. Wait til it warms up and drain the transmission/differential fluid and the final drive fluid. Over the years condensation causes a suprising amount of water to build up in these fluids, especially if the tractor has not been used hard enough to get hot. I use 80/90W grease. Dave.
art's A
12-31-2004 21:41:11
My A sometimes dose not pull 1st or 2nd out of gear all the way and when you go to another gear it locks up the transmison. If I go to the last gear I was in and pull it just past center it will disengage. Other times I have to take the top off set everything back to netral and reinstall.
Ron/PA
12-31-2004 20:51:57
I've had the same problem and I'll bet if you pull the shifter cover off of the tranny, it's a block of ice. Ron
olderguy
12-31-2004 19:49:13
I agree With Farmer Bob, we had a no move, engine kill problem on a Super A we had just bought, found ice in trans and rear end
Farmer Bob
12-31-2004 19:30:59
You could have ice frozen in the final drives and/or transmission if it has been really cold. Best let her warm up some before trying again as something could go "Snap, Crackle, Pop" and it won't be your Rice Crispies.
