Schwartz vs. Factory
Glenn F.
01-01-2005 15:41:00
Does the IH wide front for IH letter series tractors have any advantages over the Schwartz, other than collector value? Just curious, Glenn
MN Scott
01-01-2005 20:37:40
 Re: Schwartz vs. Factory in reply to Glenn F., 01-01-2005 15:41:00
In my opinion if you are going to work the tractor go with the schwartz, if you are going to show the tractor go with the factory. My two cents.
Steven@AZ
01-01-2005 18:48:44
A couple of comments: Schwartz parts are still available at a reasonable price, as are complete front ends. Schwartz is a stronger front end if you plan on using a loader or other heavy front-end implement. Heavy duty Schwartz has 6 bolt hubs that are a common implement pattern - was always helpful to me when I got a flat, just borrow one from an implement for that day...
Factory front ends are nice, turn easy enough, etc. they also increase collector value...
Personally, if I had to buy a wide front I would buy Schwartz over factory again.
Farmer Bob
01-01-2005 15:51:22
Probably not Glenn, some will argue that one will turn shorter than the other, the older original IH WFE's had the tie rods out front where they were more likely to be damaged than if they were in the back like the Schwartz units. I think it boils down to (like you said) the viewpoint of the owners. At least you can still find more replacement parts for the Aftermarket units than you can for NOS parts for the original WFE's. I have a Schwartz WFE on my '48 M and love it.
jim in ny
01-01-2005 15:46:42
the schwartz will turn as short as a tricycle
