Farmall 300 Govenor
Hogman
01-01-2005 15:41:09
Hello, My throtle lever moves 1 1/2 inches before it starts to rev up.I see in the govenor unit there are some ajustment screws.. What do I need to do??
PAULIH300
01-01-2005 16:06:44
 Re: Farmall 300 Govenor in reply to Hogman, 01-01-2005 15:41:09
You must have play in the linkage between the hand lever and the governor itself.Watch the rod that runs behind the carb carefully as you slowly move the throttle....bet there is a lot of slop there.The play is usually (in my case anyway) in the rods and bellcranks behind the dash,and the setscrew that holds the hand lever from spinning on its shaft.
jim in ny
01-01-2005 15:44:54
sounds like your govenor spring is stretched out
