clutch pedal extension for H, M?
zooeyhall
01-01-2005 18:22:06
I noticed that a supplier of H and M parts sells something called a "Clutch pedal extension". It has a clevis-type end on one side with a pin and a drilled hole on the other. It looks to be about 2"-3" long. I think it connects between the clutch pedal and the existing clutch rod.
I am curious, what would be the advantage or usage scenarios for this type of part?
Alvin Dick
01-01-2005 19:03:56
 Re: clutch pedal extension for H, M? in reply to zooeyhall, 01-01-2005 18:22:06
The clutch paddle is easier to push in with this option.
Farmer Bob
01-01-2005 19:15:39
 Re: clutch pedal extension for H, M? in reply to Alvin Dick, 01-01-2005 19:03:56
third party image
Alvin is right on the money. Here's what it looks like mounted.
DWV
01-02-2005 08:44:05
 Re: clutch pedal extension for H, M? in reply to Farmer Bob, 01-01-2005 19:15:39
Nice looking tractor farmer Bob.Notice you have
9 speed and lambert brakes also.
farmalljim10
01-02-2005 05:51:49
where do you get them and how do you put them on? Thank you ( do you have to do a split) or does it just bolt on from outside? Thanks Jim
Farmer Bob
01-02-2005 09:00:01
 Re: clutch pedal extension for H, M? in reply to farmalljim10, 01-02-2005 05:51:49
Thanks DVW, The Hiesler 9spd and Lambert disk brakes were on the tractor when I bought it. Both have worked perfectly. I would think you would have to at least remove the belt pulley assembly and maybe even the deck to install the 9spd.
