what are these springs for in my clutch assy?
Randy in Pa
01-01-2005 18:46:00
Hello Guys,
These are "not" the springs in the pressure plate. I know what they are for.
I was getting ready to start putting the 230 bell houseing back together after a pilot bearing and clutch replacement and noticed on the parts scematic that there is suposed to be 2 springs in there somewheres around the throwout bearing.
There wasnt any springs when I took it apart. I just checked the tractor and there where not any ears on anything for springs to hook too!
Can anybody tell me what the springs are for and if I need them?
Parts list says...2 spring, return, clutch release bearing(for tractors not equiped with hydra creeper)
I dont believe I have a hydra creeper. What is a hydra creeper?
I am trying to upload a scan of the parts blowup. How do you upload a photo to this forum?
Randy
Quebec Red
01-02-2005 08:27:00
 Re: what are these springs for in my clutch assy? in reply to Randy in Pa, 01-01-2005 18:46:00
Hydra Creeper was offered on the 230. The hydraulic pump ran a hyd motor that connected to the PTO shaft(externally) and because of the transmission driven PTO the tractor would move. The 4 speed trans gave 4 different ratios. An excellent creeper system rather advanced technology using hyds in 1956-57. Probably led to the hydrostatic trans 10 years later. There are several 230s and retro fitted to S-C in my area amongst market gardeners. (those diehard Farmall lads!). I imagine heat(no cooler) and limited torque could be problematic.
Randy in Pa
01-02-2005 13:21:44
 Re: what are these springs for in my clutch assy? in reply to Quebec Red, 01-02-2005 08:27:00
Well, I dont have one of those! Pretty slick though.
Thanks for the reply.
Randy
Randy in Pa
01-01-2005 18:53:51
Also there is a spring on the clutch petal for its return. It is hooked to the throwout bearing so when the petal returns the throwout bearing comes with it.
Randy
Novel Idea Guy
01-01-2005 23:58:57
 Re: what are these springs for in my clutch assy? in reply to Randy in Pa, 01-01-2005 18:53:51
Well, you know what "hydra" indicates (hydraulic). You know what creep means (to move slowly), and that many tractors have a super-slow "creeper" gear. I would put signifigant money on a "Hydra Creeper" being a hydraulic device that gives the tractor the ability to move slowly.
Dave (IL)
01-02-2005 05:32:14
 Re: what are these springs for in my clutch assy? in reply to Novel Idea Guy, 01-01-2005 23:58:57
What a novel idea, guy!
(Sorry. Couldn't resist :))
