Farmall300 HP?
Hogman
01-01-2005 22:51:48
What is the hp. of the 300 and can I beef up the hp and How??Piston and sleeve kit what size?I want the most that I can get.. Any suggetions.....
Redrider
01-02-2005 19:39:10
 Re: Farmall300 HP? in reply to Hogman, 01-01-2005 22:51:48
Hogman..You can get your 300 up to 50hp and still have a farm usable tractor. I have a 300F and 300U that I rebuilt with 3 5/8 flat top pistons,propane heads, propane intake and exhaust manifolds. The propane heads raised the compression up to about 9 to 1. You can get the compression up with step head type pistons but I think you get better combustion with flat top pistons. These two tractors will dyno 50hp. How ever if I pull 50hp out of them I do have to burn hi octane fuel or they will ping. If I don't let them pull below the governer I can run regular fuel without any problem.
CNKS
01-02-2005 13:42:27
IH rated them at 33 drawbar, 37.5 belt. Drawbar HP compares to about 25.5 for the H and 31 for the Super H.
TDK
01-02-2005 11:25:11
Search the Tractor Pulling forum for "Chads". He has a lot of HP improvement ideas for the H - 350 engines.
