Pertronix Ignitor
PAULIH300
01-02-2005 17:46:22
Its a shame Pertronix doesnt offer a 12V negative ground Ignitor for IH tractors(6V/12V Pos only).Would be nice to get rid of the points forever.
Marvin(MN)
01-02-2005 22:22:07
 Re: Pertronix Ignitor in reply to PAULIH300, 01-02-2005 17:46:22
Paul: Call John Brillman (look in Red Power Mag)and he will sell you just what you need and reasonable.I have four(4) IH tractors(one is a 300U) and the all have Pertronix Electronic systems on them. Also I used a Hitachi alternator (on the 300U) and used the same belt that was for the gen.Hope this helps.E-mail if you need more help. Marvin
randy hall
01-02-2005 20:24:57
paul i don't know where you are looking but all the m's and 450's etc. that i have changed to twelve volts and electronic ignition are negative ground.
Hayfarmer
01-02-2005 19:16:36
If you click on tractor parts above, select IH, then M, and then electrical components will show a 12 volt Pertronix ignition, first part says positive ground, if you read on it says if you have negative ground to order a different number.
Redrider
01-02-2005 19:13:11
PAULIH300..I have a 300U, 300F and a 100F that all run electronic ignition 12 volt Neg ground. So far the only thing I haven't found is a unit for the IH gas start diesels.
Hayfarmer
01-02-2005 19:10:52
In the link from here it shows IH 12 volt positive ground but gives a different number to order for 12 volt negative ground. check it out.
MagMan
01-02-2005 18:29:14
Do you mean electronic ign? I sell them. Or if its something different what is it? JON
PAULIH300
01-02-2005 18:35:44
 Re: Pertronix Ignitor in reply to MagMan, 01-02-2005 18:29:14
Yes,the electronic ignition/contact points eliminator.All information I have read (even Pertronix's website) shows only Positive ground for IH distributors (4 cyl) in 6 and 12 volt versions.For those upgrading to 12V neg ground 1-wire alternators,that sort of leaves them no choice but points.
MagMan
01-02-2005 18:44:11
 Re: Pertronix Ignitor in reply to PAULIH300, 01-02-2005 18:35:44
Now mine shows all the opisite it says 12 volt neg ground and 6 volt converted to 12 volt neg ground. I dont know what kind they are I sell aftermarket parts for tractors and machinary. I have never ordered one as of yet. JON
PAULIH300
01-02-2005 19:06:16
 Re: Pertronix Ignitor in reply to MagMan, 01-02-2005 18:44:11
I see they have no listing for 300s (C169) anyway..so...no problems!
lol
PAULIH300
01-03-2005 15:38:05
 Re: Pertronix Ignitor in reply to PAULIH300, 01-02-2005 19:06:16
If you download their catalog over at their website,under agricultural applications there is INTERNATIONAL HARVESTER,but nowhere is a 300,350,C169 listed.Is it just me??
MagMan
01-03-2005 03:56:51
I do have a listing for a 300. $90.00
