Farmall H manifold
Scott Schotz
01-03-2005 08:13:16
Hi, Since I am running my Farmall H on all gas, can I replace my old Kerosene exhaust manifold with a gas burning manifold? Will it fit with my existing carb? I figured they could be interchanged, but before I buy a new manifold I had better check
Thanks
S.Schotz
FRANK CASWELL
01-03-2005 12:43:46
 Re: Farmall H manifold in reply to Scott Schotz, 01-03-2005 08:13:16
SCOTT; IS YOUR OLD MANIFOLD ANY GOOD. I WOULD LIKE TO BUY IT IF THE FLAPPER IS WORKING. THANKS FRANK
Schotz
01-03-2005 13:21:37
 Re: Farmall H manifold in reply to FRANK CASWELL, 01-03-2005 12:43:46
Frank, Nope, it is shot. The fella that owned it had it put together with tin foil. Safe huh?
Scott
John M
01-03-2005 11:46:36
I got a used one Id sell,not perfect around the pipe but itll work fine.
John M
01-03-2005 11:46:19
John M
01-03-2005 11:46:12
jayw
01-03-2005 11:22:57
like the other fellow said it is a easy swap I purcahsed a after market for my 42 H from T.H.E. company 3 years ago and it is holding up just as well as original ther 800 number is 1-800-634-4885 they offer free shipping on manifolds
RustyFarmall
01-03-2005 08:45:54
It will be a direct swap, everything will fit. See if you can find a good used manifold before you give up and buy an aftermarket reproduction. in my opinion the new manifolds are OK but not as good as an original.
Schotz
01-03-2005 09:20:54
 Re: Farmall H manifold in reply to RustyFarmall, 01-03-2005 08:45:54
Thanks!
