Alum tube to carb from governer,( First M) HELP
Ben.So.Tex
01-03-2005 11:57:46
Just bought a M home today to show my 14 John Deeres, The engine will run real fast, if I troddle up or down their is no change in the engine speed. Their is a shaft in the alum tube that come from the carb to the governor housing, Is their a special way or position that this shaft has to be. thanks Ben
Nebraska Cowman
01-03-2005 12:04:11
 Re: Alum tube to carb from governer,( First M) HE in reply to Ben.So.Tex, 01-03-2005 11:57:46
the tip on the shaft is supposed to fit in the slot in the throttle plate. I would guess it might not be.
