A with cracks in the block deck
venda
01-03-2005 18:45:18
After removal of the head on my Farmall "A" , I noticed some small cracks in the surface deck of the block. These cracks are between two coolant holes and not anywhere near the cylinders. Is this a situation where the block is shot or does it make any difference since this area is only for coolant? Should I use some sealant when I install the head? Help!
Greg-N-CA
01-04-2005 06:19:40
 Re: A with cracks in the block deck in reply to venda, 01-03-2005 18:45:18
You might want to consider having a machine shop check for other cracks that you may not see with the naked eye. They can drill and pin the cracks for a permanent repair, although, this would require decking the block’s surface.
DelMN
01-04-2005 04:40:16
I had the same thing and I just put a lot of sealant on it and put the head back on. No leaks. I thought that I would do this before the block replacement thing. And it was certainly a lot less expensive and less work!
