M Live hydraulics pump choices
chris in LNK N
01-04-2005 11:27:46
Off of what machines (Super M, H, 300, 400, etc.) will the live hydraulic pump fit on a '48 M? I understand that one mounting bolt hole does not line up in some cases, but I can machine that particular problem. Any other considerations, and other models that will fit my M?
T.B.W.
01-04-2005 15:36:50
 Re: M Live hydraulics pump choices in reply to chris in LNK NE, 01-04-2005 11:27:46
The IH live pump from a super M 400 and 450 will work. I tried to change the front cover on my 49 M, but couldn't get the front pully off. The bottom 2 bolts of the pump fit, it is the top 2 that are off a little. I took 2, 3/8 eye bolts and opened the eyes enough to put the end of the eye in the top holes and ran a bolt through the hole in front of the the oil fill. Made a bracket for the eye bolts to hook to. Painted it red and it works fine. unless you look hard, you don't see the eye bolts. I know its not the way IH intended it, but I use this tractor and needed the live hydraulics. Love the M with the live pump. When you put the pump in, there is a punch marks on the pump gear and the timing gear. line them up. make sure you have the motor on TDC before you take the distributor off and it will line up easy
Novel Idea Guy
01-04-2005 14:30:50
For a Super M/400/450 pump to fit properly, you need the front cover and timing gears off a late late M, Super M, 400, or 450. The timing cover is drilled for the pump, and the gears are heavier-duty than the old ones.
A Super H/300/350 pump will not fit.
26Red
01-04-2005 11:43:45
I think only the pump off a Super M, 400, or 450 will fit. Also a pump from a Super W-6, or a W400. I"m not sure about a Super W-9 or the W600 or W650s...
