MW live hyd question
Stroked550
01-04-2005 12:48:51
Anyone know the specs. of the pumps used on the M&W live hyd. kits for a Farmall M (pressure/flow rate)? The belly pump was used as the tank and the suction port is only 1/2"- the port on the pump is 3/4. I'm building a new tank to take place of the belly pump. It will fit into the same opening and stick out 5" (about the same as the bottom of the belly pump). Tank will hold 3.5 gal. Any suggestions/comments?
Thanks
Ben
captaink
01-04-2005 12:54:18
 Re: MW live hyd question in reply to Stroked550, 01-04-2005 12:48:51
I can’t give flow or max pressure, but my relief valve on my loader is set at about 1100 PSI. Since you are building a tank, I would suggest a ¾ inch outlet for the suction side of the pump. That way you have no chance of restricting pump output with too small a supply hose. I have a homemade tank in my M that sounds just like what you are building, and it has a ¾ inch outlet.
T.B.W.
01-04-2005 15:23:35
 Re: MW live hyd question in reply to captaink, 01-04-2005 12:54:18
I used a 3/4 inch hose from the tank to the pump on my M. Works great
