H manifold or Header
danielgillespie
01-04-2005 14:43:09
Hi i wanted to know if i couyld make a manifold for my 45 H. the top piece has broken off and is pretty rusted into one solid piece of the bottom( I gues this is a kerosene one) I m a good welder with 1/4'' stock plate and pipe. Could one build one, i guess they would be more like headers by Jesse James. Would this also increase your HP or sominthing??
texp
01-04-2005 19:45:41
 Re: H manifold or Header in reply to danielgillespie, 01-04-2005 14:43:09
Cut off the top piece (the part that's probably broken), and weld a part of a 2" union to the manifold, then all you need to do is to screw in about 6" of 2" pipe which will just fit into the bottom of the muffler.
Larry in CO
01-04-2005 19:14:10
Bermuda Ken has the manifold, exhaust pipe and gaskets for $145. Check out cngco.com for particulars. You could also order them from this site for around $160. HTH. Larry
jayw
01-04-2005 16:32:55
It is alot easier too buy one for 120.00 than to do what your asking But good luck
Michael Soldan
01-04-2005 16:09:24
Daniel, I am not questioning your ability to do this but you realize that the intake is part of the system. It would be a trick to fabricate a custom exhaust that also allows a flow of fuel through an integrated intake with your header. It would have to be very accurate to get even distribution of fuel to each cylinder. I bought an new manifold for my H for $190 Canadian, changed it in about 10 minutes and it was done. You could spend a lot of hours trying to perfect what you have in mind..but good luck if you go for it....Mike in Exeter Ontario
Nebraska Cowman
01-04-2005 16:01:56
you could build one but then you can buy new ones for less than $150 on ebay
Brian in NY
01-05-2005 05:24:56
 Re: H manifold or Header in reply to Nebraska Cowman, 01-04-2005 16:01:56
I got a real nice solid used one from Mike at Steel Wheel Ranch for $50 plus shipping.
