Winter hearter
Hogman
01-04-2005 15:35:51
Hi yall, what kind of heater woud you all suggest for a farmall 300.Easier the better but still works good????? ?thanks everyone Scott
El Toro
01-05-2005 15:32:22
 Re: Winter hearter in reply to Hogman, 01-04-2005 15:35:51
Try Phillips & Temro at 1-800-328-6108 and see what they recommend. That tractor will start a lot easier if you have an engine heater. You can put in on a timer and have it to kick on so it will be warmed up when you need it. Keep those hogs fed. Hal
PAULIH300
01-04-2005 15:56:43
If you are talking of an engine heater to make starting easier,I would go with a battery blanket.If you can keep the battery warm,it will have good cranking power.
Plus put some Isopropyl dry gas in the tank.
Fresh spark plugs....
and store it inside a heated building...
lol
(mine is under a plastic tarp out in the cold...)
