'27 Regular:This winter's Project
KevinH
01-04-2005 16:59:42
third party image
This is the decal on the carb side of my '27 Regular. I've never seen this decal before and was wondering if anyone could tell me what it says(The words are no longer readable)? I can't tell what the decal on the mag side was(too much surface rust). Also, is this decal available in any of the decal sets? Thanks, KevinH
Charles Park
01-05-2005 06:37:22
 Re: '27 Regular:This winter's Project in reply to KevinH, 01-04-2005 16:59:42
You might call O. E. M. Tractor Parts to inquire about the decals for this tractor. 800-283-2122.
KHarbin
01-04-2005 17:32:33
 manifold in reply to KevinH, 01-04-2005 16:59:42
Thanks. By the way, The manifold I got from you for that tractor was a real beauty. I'll probably be emailing you in a week or so with some other parts needs.Kevin
Nebraska Cowman
01-04-2005 17:24:48
"Be sure Gasoline valve is closed tightly before opening kerosene shut-off neele valve. If both valves are open at the same time kerosene will mix with gasoline making it unsatisfactory for starting" Not the exact wording but close. you picture is sort of hard to read.
Nebraska Cowman
01-04-2005 17:22:45
Sloroll
01-04-2005 18:02:25
 Re: '27 Regular:This winter's Project in reply to Nebraska Cowman, 01-04-2005 17:22:45
I thought that decal went on the starter tank.
KevinH
01-04-2005 17:01:58
 Subject should have said '27 fuel tank decal in reply to KevinH, 01-04-2005 16:59:42
oops, I hate autofill.
