farmall c just dies
william pugh
01-05-2005 20:17:29
My farmall c will be running fine then just die like it lost its electric power it does not have a mag. Then it won't crank or anything it is like the battery is dead. Then I pull start it it will fire right up and run fine I can then shut it off and restart it no problem. I changed the battery cables and battery but still didn't help. Thanks for the help
captaink
01-06-2005 11:23:11
 Re: farmall c just dies in reply to william pugh, 01-05-2005 20:17:29
I'm going to guess that you have a very bad connection either at the battery or at the other end of either or both of the battery cables. Check them out and clean them up. Should help at least...
Brian Schmidt
01-05-2005 20:22:54
If it won't crank, about the only thing could be the ground cable. Where are you grounding it to?
Jeff in Mass
01-07-2005 09:53:52
 Re: farmall c just dies in reply to Brian Schmidt, 01-05-2005 20:22:54
I don't know much about tractors but I had a similar problem with my 200 and I figured out that the carb was flooding if the throttle was too high for too long. If that is the problem just don't crack it up so high.
