Valve cover on a 460
Pierre Lanoue
01-06-2005 05:42:30
What is the torque for the valve cover bolts (3 of them).
Thanks! :)
Glenn F.
01-06-2005 09:42:55
 Re: Valve cover on a 460 in reply to Pierre Lanoue, 01-06-2005 05:42:30
I guess there's specs for every bolt but it sure seems common sence would be your guide here. Tight enough to compress the gasket a bit, stop leaking, but not too tight resulting in a bent cover or squeezed out gasket. I have never worked on a 460, but would it be any different than any other valve cover? Glenn
Pierre Lanoue
01-06-2005 12:13:48
 Re: Valve cover on a 460 in reply to Glenn F., 01-06-2005 09:42:55
Thanks! I have tighten them as I see fit and there doesn"t seem to be any leaks. I had to get it done quickly because we are having a snowstorm with 20cm (8 inches)expected by tonight.
Thanks again for the quick response.
