missing H
Larry Senter
01-06-2005 16:24:37
she idles good ,give her gas and she starts missing and thin will smooth out. can someone tell me what to look for?
thanks
Larry
Gordo
01-11-2005 08:27:51
 Re: missing H in reply to Larry Senter, 01-06-2005 16:24:37
Mea Culpa. Went to my carb book and see that your H probably does not have an accel pump in it. Check float level. Also check distributer advance.
GW
Gordo
01-09-2005 08:10:17
If a gas engine "misses" or stalls/hesitates when you "accelerate", then smoothes out after a bit, it is the accelerator pump in the carb. This little baby sends extra fuel in there for acceleration. THEN when the engine is up to it's new required rpm it runs on the fuel through the main jet. The engine is either getting too much fuel or too litlle during this acceleration. You can tell which by the appearance of the exhaust gasses, Black, too rich, white too lean. Fix the accelerator pump accordingly.
Gordo
Novel Idea Guy
01-07-2005 10:25:38
Missing, or sputtering? If it smooths out, it's sputtering, and it's fuel related. My experience with tuning model aircraft engines would tell me "too rich on the low end."
dej(JED)
01-07-2005 07:45:15
Larry----- Start it up in the dark and see if it isn't arching off of the wires or the coil somewhere. It sounds like electrical to me.
John
MagMan
01-06-2005 16:55:54
Try turning out the main jet on the bottom of the bowl a turn or so. JON
MagMan
01-06-2005 16:49:07
