Uh oh
Wes in Ohio
01-06-2005 17:02:29
Well I been slowly but surely putting my 300 Utility back together, when I was about to put the distributer back on well first I need top dead center, but I can't get the crank to move, now I just had her moving 2 months ago when I checked my compression, but right after I power washed it. Is it possible the pistons froze in that short amount of time. Any suggestion appreciated
Paul K.
01-06-2005 18:27:10
 Re: Uh oh in reply to Wes in Ohio, 01-06-2005 17:02:29
Wes. If you have a TA on your 300u, try pulling back on the lever to low side. Had a 460 that I redone and found out I couldn't turn crank unless TA was in low.
Wes in Ohio
01-07-2005 14:04:51
 Re: Uh oh in reply to Paul K., 01-06-2005 18:27:10
I got a lot things to try, thanks to all Wes
lee
01-06-2005 17:38:21
pull the plugs and squirt it up good with PB blaster, wd40, liq wrench, whatever you got on hand. If you power washed it, the plug recess
area will trap water. If you pulled the plugs soon after without blowing out the recess the water goes in the cylinder. She'll be stuck in a week. Soak it up good, you should be able to free it. It's always a good idea to get a machine running soon after power washing and to cover sensitive components beforehand.
K.B.-826
01-06-2005 17:32:41
Like CNKS said the starter is the best place to start. Very common for them to jam and lock up. Also, you could be stuck in gear. Have someone hold down the clutch pedal while you try to turn.
CNKS
01-06-2005 17:17:44
Possibly, if you got water in the cylinders somehow. If so it shouldn't be stuck too bad. Try loosening the starter first, in case the gears are jammed.
Wes in Ohio
01-06-2005 17:26:42
 Re: Uh oh in reply to CNKS, 01-06-2005 17:17:44
well I'll try the starter but I was just trying to turn the crank by hand with a breaker bar
Andy Martin
01-07-2005 05:24:35
 Re: Uh oh in reply to Wes in Ohio, 01-06-2005 17:26:42
If the starter is jammed into the ring gear it will hold the flywheel firmly, and the crank is connected to the flywheel.....
Nebraska Cowman
01-06-2005 17:10:41
ice?
Wes in Ohio
01-06-2005 17:17:37
 Re: Uh oh in reply to Nebraska Cowman, 01-06-2005 17:10:41
no it's not ice I'm in a heated garage
