Need help for hydraulics on my 400
Farmall Kelly
01-07-2005 09:22:37
I was low on fluid and just trying to get one more load.... when I dumped, my hydraulic bucket swung like a trip bucket. After that all 3 ports no longer worked. I changed the pump - no luck. Is there some sort of relief valve or ?? I have since changed the fluid as well.
thanks.
Farmall Kelly
01-10-2005 08:47:15
 Re: Need help for hydraulics on my 400 in reply to Farmall Kelly, 01-07-2005 09:22:37
I popped the top off of what I think is the relief valve. The spring inside is stiff and looks to be in good shape. There is another cylinder that I removed - slid out easily... everything looks clean. I ran the tractor thinking that fluid would be pumped out making a mess (nothing). Was this a reasonable test? IS my junkyard pump junk? Any help appreciated. Thanks.
(Can't loosen the line off the pump as intake and outflow are mounted as one.)
kjm
01-07-2005 17:56:33
FK,I blew a hose on the loader on a 450 and the loader wouldn`t work afterward so I loosed the hose at the pump while it was running(heck of a mess)and it has worked fine ever since.It was air locked. God bless,Kjm
old
01-07-2005 11:04:02
Yes theres a relief valve its under the hood on the left side
Farmall Kelly
01-07-2005 11:43:22
 Re: Need help for hydraulics on my 400 in reply to old, 01-07-2005 11:04:02
Thanks.... I saw what looked like a breather with a filter. Can you give me some ideas on what to look for (troublewise)or if there are any fixes/tricks/tests etc on the relief valve? or other parts that may be the trouble.
old
01-07-2005 12:31:04
 Re: Need help for hydraulics on my 400 in reply to Farmall Kelly, 01-07-2005 11:43:22
Theres a number of things that go wrong in that area. You may have got some junk it there keeping it from working right etc.
