H exhaust and fan
Gordo
01-07-2005 09:24:20
I have two items I need help on. First can someone send the exact dimensions of the original muffler on the H? A 1949. Would like to have inlet dia, od, of the pipe both before and after the muffler, oal, length of inlet and exhaust pipes. OD of muffler section. Then what color should the fan be painted. I imagine there would be red overspray on the inside ofthe blades from final paint, but what color was it when assembled?
Andy Martin
01-07-2005 09:34:34
 Re: H exhaust and fan in reply to Gordo, 01-07-2005 09:24:20
I've heard it said many times on this board that the letter Farmalls were painted all red, this includes wires, spark plugs, distributor cap, fan, belt pulley, etc.
j a nicholson
01-07-2005 10:13:22
 Re: H exhaust and fan in reply to Andy Martin, 01-07-2005 09:34:34
The pipe is standard well pipe 2" nominal I.D. The threads are 2"NPT standard plumbing pitch tapered threads. The factory pipe length I do not know, we use 14" including threads. When replacing the pipe, always use a 2" pipe tap (its a big one) to clean the threads in the manifold. The old pipe will have left scale in the manafold, and the new pipe will jamb on it and be way reduced in resistance to being broken by a limb. high temperature molebdenum, or mica anti sieze compound is also to be used to allow replacement in the future. J A
