Link Bracket
Coax
01-07-2005 11:37:05
Can Someone tell me what the IH part # is for a 1959 240 utility Top Link bracket? Its a Triangular shaped 3-bolt unit thats missing on my Beast.. Thanks in advance
Randy in NE
01-07-2005 12:14:58
 Re: Link Bracket in reply to Coax, 01-07-2005 11:37:05
I am lookin at the drawing. I not sure if you are talking about the attaching plates. There is a left and a right one. The left is 517795R21. The right is 517796R21. If that isn't it then I would need a little more description for it. Those are the only two triangular type parts that I see in the drawing.
Coax
01-07-2005 12:23:43
 Re: Link Bracket in reply to Randy in NE, 01-07-2005 12:14:58
All I've got is three holes in the back of my back deck . I'll try and post a picture in a bit...Thanks
Coax
01-07-2005 13:11:21
 Re: Link Bracket in reply to Coax, 01-07-2005 12:23:43
third party image
Heres a pic of where my missing part goes
Jim Becker
01-07-2005 18:11:31
 Re: Link Bracket in reply to Coax, 01-07-2005 13:11:21
The numbers Randy gave were for the attaching plates for the Fast-Hitch on a 200, not applicable to what you are working on.
IH only used a center mounted top link bracket with the 3-point Industrial Hitch (no draft control). The 2-point and 3-point Fast-Hitches did not use it. The part number is 372968R1.
coax
01-07-2005 21:53:26
 Re: Link Bracket in reply to Jim Becker, 01-07-2005 18:11:31
Thanks guys
