300 Transmission Update - Hugh McKay and Kelly C
ted411
01-07-2005 15:09:48
Well I got the gear I needed for the 300 yesterday and began installing it today. I got the tractor and the upper shaft and gears out pretty easily. However, as luck would have it the gear is for the lower counter rotating shaft and it is giving me some trouble. I got the retaining bolts out of the center bearing holder but cannot get the PTO unit out of the rearend. Without removing the PTO I do not see how I can get the lower shaft out. I can't drive it back far enough to lift it out because it hits the PTO drive shaft. I removed the 4 larger long bolts from the PTO housing as well and the bolts on the smaller inside(I don't think I need to remove the bolts on the inside but did because I was having so much trouble getting the PTO off). The PTO unit is still very tight. I think it is just stuck in the housing. Does anyone have any suggestions to help me get the PTO unit off? I am afraid to bang in too hard for fear that I will crack it and besides there is very little room to hit or pry it anyway. If I could just get it removed I think it would go pretty smoothly.
Thanks in advance,
Ted
DWV
01-07-2005 16:48:06
 Re: 300 Transmission Update - Hugh McKay and Kelly in reply to ted411, 01-07-2005 15:09:48
Ted if you have the live PTO and have removed
the 4 long 1/2 inch bolts,theres a O ring on PTO
that squeezes into trans housing takes some force to start PTO out.
Hugh MacKay
01-07-2005 16:36:41
ted: Put lots of penetrating oil around the perimeter of PTO both inside and out. Walk away for couple of days.
lee
01-07-2005 16:06:24
if all the bolts are out it stuck in place.
Might try to drive a knife edge or stout putty knife edge or thin chisel tapered edge between cast flanges around the perimeter where access permits. Shoot it up with penetrating oil. Try again in the morning. If you own a torch you can heat the perimeter flange but not to excess, just to weaken the gasket grip. Wear safety glasses.
