784 manifold
TL
01-07-2005 16:29:44
Does anyone know where I could get a manifold for a 784.The case ih dealer said they are not available.Thank you for any help.
JB2
01-07-2005 19:35:00
 Re: 784 manifold in reply to TL, 01-07-2005 16:29:44
Hi TL, broke one on 454D where threaded exhaust pipe goes into manifold many years ago. Took it to local welding shop and had it welded. Still holding today.
Hydro84 and 884 should have same manifold and possibly 684.
Good luck
JB2
TL
01-07-2005 17:55:58
 exhaust in reply to TL, 01-07-2005 16:29:44
exhaust
K.B.-826
01-07-2005 19:36:39
 Re: exhaust in reply to TL, 01-07-2005 17:55:58
Check with a parts yard. If you have vertical exhaust, the part number is 3136066R12. If you have underslung exhaust, you need 3055276R12. This should not be a hard part to find. All four cylinder German diesels with underslung exhaust use the same manifold. The manifold from an early engine with vertical exhaust would bolt to the head, but the pipe to the muffler is attached to the manifold with two studs instead of four like the 784.
K.B.-826
01-07-2005 17:19:09
Intake or exhaust?
