Clutch release bearing and pilot bearing
Tailhunter
01-07-2005 17:51:15
I have my H split. Rebuilding the engine. How do these bearings come out? They look like they need replaced also...Where is the best (cheapest) place to buy rebuild parts for an H. Thanks as always...
old dan
01-14-2005 18:36:43
 Re: Clutch release bearing and pilot bearing in reply to Tailhunter, 01-07-2005 17:51:15
jkfish
01-10-2005 13:17:09
I have taken 6 or 7 out this past year,including an H,with a 1 jaw slide hammer puller.
Tailhunter
01-11-2005 17:37:31
 Re: Clutch release bearing and pilot bearing in reply to jkfish, 01-10-2005 13:17:09
Thanks..... ..... ..
Roger WI
01-08-2005 16:18:36
Someone else on this forum gave me this idea and I have been using it ever since. I screw the right sized thread tap into the pilot bearing and as it bottoms out it pushes the bearing out. Also, people have used a shaft that fits the pilot bearing by filling the pilot bearing with grease and then pound on the shaft and it extracts the bearing (have to cover with a rag as some grease flies out). Roger
PAULIH300
01-08-2005 15:24:19
Pilot bearing pullers only run around $20-30,and make the job far easier.There is one brand that uses jaws like an inside jaw puller,that crank out when you turn the handle,and then there is a slide hammer deal to slam it out.Cant remember the brand but anybody that sells ETW/ATD tools can get it.
Randy in PA
01-07-2005 20:10:04
To take out the pilot bearing you need a plow chisel(cape chisel? cant remember) The old bronze will split easily. Just be careful not to booger up the bore when you do this. Any nicks can be carefully cleaned up with a small roundish jewelers file. The new one should drive right in with a punch the same size as the bearing.
The sleeve can be driven out of the throwout bearing by using a piece of pipe the same size as the sleeve (little smaller)and a hammer in between 2 vise jaws. Then I pressed the new one on using the vise as a press.
Randy
JLE
01-08-2005 16:14:32
 Re: Clutch release bearing and pilot bearing in reply to Randy in PA, 01-07-2005 20:10:04
Farmall "H" has a ball bearing pilot bearing.
Jeff_MI
01-07-2005 18:09:36
I get most of my parts through Little Red Tractor Company in Nebraska.
I haven't worked on my H, but I replaced my BN clutch release bearing. I didn't have an arbor press (which would be best), so I just destroyed the original bearing with a hammer and chisel, then press fit the new bearing in with a block of wood and hammer on a flat surface. I was careful not to touch anything but the bearing with my chisel - as it came apart I was able to loosen and remove the bearing surface. It's crude, but it worked well and took about 20 minutes total.
