H/ SH block bore ?
Andy in Ohio
01-08-2005 20:10:14
Is the bore in the block of an H the same as a SH before the sleeves are installed? Or will a SH kit fit in an H block? The H does have hi compression pistons if that makes a difference. Thanks, Andy
ChadS
01-10-2005 08:17:37
 Re: H/ SH block bore ? in reply to Andy in Ohio, 01-08-2005 20:10:14
H is 3-3/8 Super H is 3-7/16, and had an overbore kit for 3.5 bore for the H-Super H series engine. the sleeves from the H up to the 3.5 overbore will fit the older H-SH block style. 3-5/8,,, pull out the sleeves, and run the C-175 head gasket on the H block, Hope this helps,, ChadS
junkyard dog
01-09-2005 16:17:50
SH&H are not the same bore. H is 3 9/16 bare bore don't know whatSH is BUT SH over bore or 300 pistons will slide right in w/o sleeves
DWV
01-09-2005 06:18:47
Around 1/8 inch differance in diameter of block
bores.
