140 into an A
rick in sc
01-10-2005 17:40:06
Can a 140 engine be installed in a 46 "A" without a tremendous amount of trouble? Thanks!!!
Hugh MacKay
01-11-2005 04:37:19
 Re: 140 into an A in reply to rick in sc, 01-10-2005 17:40:06
Rick: The engine will bolt right up with no problem. You will probably need to do some modification on coupling the radiator. The A and SA had no water pump. Water pump on 100 and 130 basically covered the bottom end of water jacket, and that was a relatively easy change over. The 140 however has water pump on the fan hub. That may make it a bit more difficult. May also make it easier.
I have a SA and 140, will compare later today, and let you know what obstacials I see. In the meantime you may hear from someone who has tried or done this change. I will get back this evening, with my opinion.
rick in sc
01-11-2005 16:58:09
 Re: 140 into an A in reply to Hugh MacKay, 01-11-2005 04:37:19
Thanks Hugh, I"ve got an "A" that is cracked and had already been repaired once and I"ve only been able to turn up a 140 engine near here (NW S.Carolina)and was looking at my options.The extra power won"t hurt either as this "A" is an all fuel model so it"s not exactly a powerhouse if you know what I mean!!
Hugh MacKay
01-11-2005 17:56:55
 Re: 140 into an A in reply to rick in sc, 01-11-2005 16:58:09
Rick: I didn't get a chance during daylight to have good look at my tractors. I went away early this morning and it was dark by the time I returned. I will try and do better in morning. Unless I get a call I should be here until good daylight. I'm just a bit rusty on 140 route of rad hoses. I haven't had 140 near as long as SA and 130.
Stan(VA).
01-12-2005 06:37:29
 Re: 140 into an A in reply to Hugh MacKay, 01-11-2005 17:56:55
You will need all the accesories from the 140 (water pump and lower radiator hose connection, fan, generator) as these are all driven by a single thinner fan belt. I don't know how bad the interference will be, but I think the upper radiator neck is going to be the problem. On the early tractors theupper neck and radiator inlet join at about a 45deg angle, on the 140 the upper neck points straight up and the radiator inlet points straight back. It uses a radiator hose with a 90deg bend. The 140 radiator is going to be taller and wouldn't fit under his grill. I think people have done this swap before (I've seen a C153 in a C), but don't know what was required on the upper connection to make it fit. Didn't know what the issues were at time, so didn't look close enough :(
Stan(VA).
rick in sc
01-12-2005 17:02:45
 Re: 140 into an A in reply to Stan(VA)., 01-12-2005 06:37:29
Thanks Stan, I may have to rethink this idea as this engine is missing the accessories.
