Can you identify year and model for me? Farmall
Tom Trimble
01-11-2005 00:29:38
third party image
I know nothing about tractors but am trying to help a widow out. She ask me to see if this tractor was worth anything. I don't even know how to identify the tractor. I do know it runs. Please email me with the identification if you know. I'm sure somebody does!
Thanks,
Tom
Andy Martin
01-11-2005 05:45:16
 Re: Can you identify year and model for me? Farmal in reply to Tom Trimble, 01-11-2005 00:29:38
Because the Farmall Regular is shedded and runs, and it looks to be pretty complete, it has some real value.
The location is important, and family history (such is it a one-owner?) can also increase value.
The oil tank in the backkground makes me think it is in the northern part of the States.
Maybe someone else will estimate prices but it is worth at least $500, probably $1,000 but not over $2,000, from what I've seen.
James Herrman
01-12-2005 21:44:42
 Re: Can you identify year and model for me? Farmal in reply to Andy Martin, 01-11-2005 05:45:16
What are the casting numbers on the front of the bolster (front steering housing)????? ?? Jim in ILL
Tanner Clark
01-11-2005 05:18:19
Yes that is surely a Farmall Regular.
pg
01-11-2005 01:34:10
it is a farmall regular. made between 1924-32. on the tool box is a serial number plate. the number will tell you the year. also on the left side frame rail, top, by clutch, a number will be stamped, it will probably match the tag on tool box. post the number and someone can tell you the year. pg
Slorroll
01-11-2005 02:39:33
 Re: Can you identify year and model for me? Farmal in reply to pg, 01-11-2005 01:34:10
By the brake handle (rounded knob on top)and seat (channel steeel support)it would be 29-32 Farmall Regular.
ihkovas
01-11-2005 10:06:55
 Re: Can you identify year and model for me? Farmal in reply to Slorroll, 01-11-2005 02:39:33
And the IHC built air cleaner was used on serial numbers T103736 and up,so that would make it 1930-32.
Sloroll
01-11-2005 11:52:52
 Re: Can you identify year and model for me? Farmal in reply to ihkovas, 01-11-2005 10:06:55
Good catch!
