F14 fuel problems
John M
01-11-2005 14:33:09
Im at my wits ends with this dang 14 of mine.I have the float set a good bit lower than spec and it still floods bad when trying to start it.Anybody know the fuel level in the bowl with the top off of the carb,and while Im thinking can someone verify the float settings just to make sure I have it right and not mixed up with some thing else?Thanks!
ET
01-11-2005 18:06:53
 Re: F14 fuel problems in reply to John M, 01-11-2005 14:33:09
I had a flood problem with my F12 and it tuned out as the float droped it touched the sid of the bowel and stuck. Then I would take it apart and check the float level and and everything would seem ok. Then after a few minutes of running it would start flooding again. Finaly I noticed the shiny spot on the side of the float where it was striking the bowel.
KevinH
01-11-2005 15:54:12
Oh yeah, one more thing, the bypass line back to the tank had become clogged and the fuel pump was actually pushing the needle open and flooding the engine. Just another maybe... Kevin
KevinH
01-11-2005 15:51:01
As you may remember from several years ago at Dacusville, I suffered the same problem. This may not be much help, but after months and months of thinking, trying, and asking, I gave up and started buying every carb and piece of carb I could find. Finally, I came up with enough to put together a dang good carb. Now my f12 starts and runs great(unless someone is watching me try to start it, but I think there's a little evil in her somewhere that does that just to make a fool of me). Anyway, if ya need some carb parts, let me know, I may have what ya need. Kevin
John M
01-11-2005 16:13:48
 Re: F14 fuel problems in reply to KevinH, 01-11-2005 15:51:01
Yea,I remember that.If you remember mine was hard to start as well.I never really got that out of it,but I put up with it,as long as it didnt rain!I have been going through it and am trying to get it right and do a proper restoration on it.The bolck needs repaired where it crack from freezing many years ago,it doesnt leak bad,but I know itll get worse.the ranny needs a good cleaning and its getting a new paint job.The old restration is showing its age.
I did pretty much the same thing as you did with the carb,and my total is up to about 8 parts carbs,not a single one had a good float so I bit the bullet and got a new one from Rice. I feel as if I clean one more of them Ill have brass fingers!Gas was getting the oil via the pump so I replaced it as well with a kit from Rice.Its pumping good now.Already rebuilt the mag and its hot.I just cant narrow the problem on the carb down.Oh well,Ill get it soon I hope!
bill olson
01-11-2005 18:31:15
 Re: F14 in reply to John M, 01-11-2005 16:13:48
does your F14 have a starter , if so could you give me the nameplate data I have a I14 I am restoring the starter was missing and I cannot find any data or where to buy one thanks bill
