706 glow plugs not working
fedgar
01-11-2005 17:46:05
Need help with a 706 glow plug problem. When I push the glow plug button the needle on the gauge only goes over about 3/4 of the way to the right. I've tested the batt. with a load tester so I know they are good. Also checked the batt. connections. I'm getting power to the plugs. So what I need to know is do I have a problem with the plugs, or with the resistor by the gauge? Thanks for any help. Gary
Bob
01-11-2005 18:20:45
 Re: 706 glow plugs not working in reply to fedgar, 01-11-2005 17:46:05
Unhook all the glowplugs, and check them individually, to verify that each draws current.
I use an ammeter, fed from the battery, and verify the current draw of EACH glowplug, but even momentarily touching each terminal with a test lead, and verifying that there is a spark will give you and idea that they are all working.
K.B.-826
01-12-2005 20:52:13
 Re: 706 glow plugs not working in reply to Bob, 01-11-2005 18:20:45
Bob, how many amps should one of these D-282 glowplugs draw? I've never been able to find a clear answer on that.
