Help with Single wheel front
dupontsniper
01-12-2005 07:02:14
Hi, I have a single wheel front that I bought thinking it was for an H, but the numbers are not the same as the H. Numbers on the casting are 23744 DA. Is this for a C? It has what looks like an additional plate extension welded on the mounting surface, with a total of 6 holes. The 4 that appear original are 3" apart from front to back, and the front row is 4" apart left to right and the back row is 5 1/4" apart left to right. The plate that looks added on are 4" apart from front to back, and 4" apart from left to right.
look something like this
front * *
jerryh
01-14-2005 06:50:20
 Re: Help with Single wheel front in reply to dupontsniper, 01-12-2005 07:02:14
Are you needing a single front for an H? If you do my brother has one for an H and I believe it has a 10 or 12 inch wheel and tire on it he also has a tall one I think it is 20" for an M
CNKS
01-12-2005 07:40:14
Your number does not match either. I have C/H/M parts manuals. These are for the fork only, I assume that's what you mean. C, 52950 or 57895; H 6195; M 5676 or 8298. The extension you refer to could be for steering the rear wheel of a semi-mounted plow, etc; but those are usually part of the piece you attach to, not the fork. I suppose it would work welded to the fork, though.
Randy in NE
01-12-2005 07:32:50
According to the parts manual the C uses a Fork, Front Wheel with numbers 52950DA or 57895DA. I am assuming that you are referring to the fork/yolk.
