Farmall 'H' weight??? (on front and back wheels)
David Schumache
01-12-2005 07:58:10
Would anyone know what the weight is on the front wheels and also the rear wheels of the 'H'??
withouy water or weights.
I read the weight of the tractor is around 3150# dry.
Thanks
Hugh MacKay
01-13-2005 03:16:42
 Re: Farmall 'H' weight??? (on front and back whee in reply to David Schumacher, 01-12-2005 07:58:10
David: I agree with others, it will be difficult to get an H much under 4,000 lbs. On the percentage I do know a Farmall 300 will come in about 65% rear and 35% front with chloride and one set of rear wheel weights.
Dave Olson
01-12-2005 16:08:16
third party image
Weight of my '45 H is 4080 pounds. No fluid in the 10x38 tires, wheel weights, fenders, belt pully.
Here it is sittin in front of the house last month.
Dave Olson
CNKS
01-12-2005 09:32:38
I agree with Earl and Rusty. I think the only way you will get it below 4000 is with no weights, ballast, belt pulley or belly pump. I would tend to agree with the 60-40 as Rusty says, but have never weighed one.
RustyFarmall
01-12-2005 09:17:19
I don't have an exact figure, but I think the weight distribution is approximately 40% front, 60% rear. I could be off a little.
earlschieb
01-12-2005 08:08:53
Well, I never weighed the front and rear seperately, but my 1951 H, with 13.6 x 38 rear rubber, 6:00 x 16 fronts, all 4 tires new, with fenders, light bar toolbox, NO weights, NO fluid in the tires, weighs 4050 lbs. Maybe this will help you some?
