Substitute 560 engine in 460 tractor
Old MD
01-13-2005 10:11:04
I have a 460 farmall diesel with a blown engine. I've been told I can replace the 460 engine with a 560 engine with very little modification or replacement of parts or recalibration. (IE use the same head, same fuel pump settings, etc.) Is this true and if not, what else needs to be replace, modified or recalibraqted to make the 560 engine work in a 460 farmall
Aces
01-13-2005 11:17:32
 Re: Substitute 560 engine in 460 tractor in reply to Old MD, 01-13-2005 10:11:04
Old MD depending how bad the 460 engine is you could put in 560 crank and pistions and the way you go.
ejr
01-13-2005 11:01:35
It will go right in.Use your 460 rear motor plate,clutch and presure plate.You may want to set up the injection pump some for the 560 engine.The only diff. between them is stroke 460 is 3 11/16x3 11/16 560 is 311 /16 x4 25/64 these are diesel no.
