1944 Farmall M hood decal
Brad in WA
01-14-2005 22:29:48
What should the hood decal read? . . . McCormick or McCormick - Deering?? ss# 77532
Floyd Williams
01-15-2005 07:08:12
 Re: 1944 Farmall M hood decal in reply to Brad in WA, 01-14-2005 22:29:48
Do you know what might be wrong with my farmall.It was froze up so i took the head in and had it rebuilt. I got it to run.the only thing is i could not get throttle. It would only idale.Know it does not start. Do you know what might be wrong.
captaink
01-18-2005 11:47:42
 Re: 1944 Farmall M hood decal in reply to Floyd Williams, 01-15-2005 07:08:12
Check to make sure that the linkage between the governor and the carburetor in connected correctly. There is a square block that goes on the square peg on the throttle butterfly in the carburetor that often are put together so that they are not hooked together properly. You get either idle, or uncontrolled RPM when this is not assembled properly.
John M
01-15-2005 06:35:02
third party image
Like this
Brad in WA
01-15-2005 10:22:48
 Re: 1944 Farmall M hood decal in reply to John M, 01-15-2005 06:35:02
Mine looks just like that except I have a wide front end. I don't know how to post a picture, or else I'd send you one. Your M look great. BKim9166@aol.com How about sending me a picture to my email? Thanks in advance
John M
01-15-2005 10:47:42
 Re: 1944 Farmall M hood decal in reply to Brad in WA, 01-15-2005 10:22:48
third party image
I have two pics of it in tractor photos,that one and this one.You can right click on it and hit save or save as or something like that.I have others of it but none are "posed" like that
Old Red Dave
01-15-2005 05:50:40
"McCormick Deering" is how they came from the
factory in 1944. (Some years before the other
name you mentioned was used.) Yes, I had the
good fortune to have "discovered America" before
the new 1944 "H" arrived at our homestead.
