TRACTOR ID
BKing
01-15-2005 01:36:16
Ok, I lookin at an International utilty tractor serial # 10798 S-W. The tractor has a International loader and it looks like the original color was red then yellow now very dirty.
It does have a shuttle shift. I found out the W in the serial number indicates this. I haven"t been able to find any other numbers other than the serial number. Didn"t have the camera when I first seen the tractor but plan on getting one. I do think that this tractor is too big to be a 340. It also has what looks like a very heavy cast iron grill and pressed steel wheels that support 14.9-28 tires. I couldn"t tell how many gears it had but I believe it does have a HI- LOW range indicated by the small shifting lever right behind the main shifter. I"d kinda like to know what I have before I bring it home. Thanks
BKING
01-15-2005 03:08:07
 Re: TRACTOR ID in reply to BKing , 01-15-2005 01:36:16
CORRECTION ON SERIAL NUMBER 10798 Y-W
