clutch linkages
cory scharf
01-16-2005 16:19:43
Were can i find good new or used linkages.The one goes from the clutch pedal and hooks to the pivet pin that hooks up the the link that operates the the clutch.Also need the pivet pin one.They both are wore pretty good on both ends.Is there something i could do to fix this or could i get them somewere?
CNKS
01-16-2005 18:12:37
 Re: clutch linkages in reply to cory scharf, 01-16-2005 16:19:43
A machine shop can put bushings in and make it good as new, they can also repair or replace the shaft -- might cost $150-200 depending on their hourly rate and how much they have to do. You didn't say what tractor. I had the clutch, one brake pedal and a new shaft done on my Super H. Otherwise salvage, or someone on this board might have parts that aren't too worn.
