farmall I-6
DAVID R HESS
01-17-2005 10:03:14
just bought one yesterday, a 1945, does
anyone have info,parts or anything on this?
thanks dave in e pa
Harold H
01-17-2005 11:53:25
 Re: farmall I-6 in reply to DAVID R HESS, 01-17-2005 10:03:14
Your tractor is a International I-6, not Farmall. It is the industrial version of the McCormick W-6. It has the same engine as the Farmall M row crop tractor. The main differences in your International I-6 and a McCormick W-6 are: different wheels, different front axle, foot accelerator, pintle hitch standard (regular drawbar optional), hydraulic brakes were optional, different gear ratios. Standard color was red but could be painted any color. Most popular industrial color back then was safety/industrial orange. Industrial yellow did not generlly become a standard color untill the late 50's.
Harold H
DAVE HESS
01-17-2005 18:01:04
 Re: farmall I-6 in reply to Harold H, 01-17-2005 11:53:25
THANK YOU HAROLD. IT IS AN INTERNATIONAL AS U SAY
(ALL I HAD TO DO IS LOOK AT HOOD AND SN,)
I AM TOLD BECAUSE IT IS I SERIES 6, IT HAS AN EIGHTH INCH OVERBORE STD. MAKING IT A 264 CI
IT HAS LESS THAN 50 HOURS ON AN IN FRAME OH
SLEEVES PISTONS RINGS CONN BRG, VALVE JOB.
SOUNDS REAL SWEET. POWER OUT THE WAZOO.
THIS GOOD AS IT WILL BE REQUIRED TO WORK FOR ITS KEEP. I WILL START IN THE SPRING WITH HYDRAULICS
MOUNTED ON THE FRONT. MUCH TO LEARN, JUST GOT HER YESTERDAY. THX AGAIN
