TD-9
TD-9 Mark
01-17-2005 12:49:39
I have recently come across an old TD-9 dozer that is missing some parts. The water seperator assembly is missing from underneath the gasoline tank, and several of the king pins are missing from the blade linkage. The batteries are missing, as are the headlights. I have not seen reference to any of these parts in the parts pages of this site or any other, except for the lights. Any idea where I might find any of them? Is this a 6 volt or 12 volt system?
old
01-17-2005 15:14:57
 Re: TD-9 in reply to TD-9 Mark, 01-17-2005 12:49:39
If you aren't to far from me in Missouri I know of a salvage yard in Versallies Mo
Brad in WA
01-17-2005 19:46:06
 Re: TD-9 in reply to old, 01-17-2005 15:14:57
Do you think they would have a grill emblem for my TD-6? BKim9166@aol.com Thanks
old
01-17-2005 20:53:37
 Re: TD-9 in reply to Brad in WA, 01-17-2005 19:46:06
Drop me an e-mail and I'll give you there phone number
Geoff NY
01-17-2005 15:13:28
Do you mean a TD-9 or a T-9? Is it the gas or the diesel? It would be a 12 volt if diesel. Also if a diesel them water separator is down by the injection pump. Get a little more information and try again. All parts are available somewhere. Good luck!!
Ron in Nebr
01-17-2005 16:48:03
 Re: TD-9 in reply to Geoff NY, 01-17-2005 15:13:28
Geoff, it is possible he DOES have his information correct, since, as I'm sure you are aware, the Diesel versions did indeed have a small gasoline tank that had a water separator/sediment bowl underneath it that they used for starting.
I think that in a pinch a standard sediment bowl off of any gas tractor could be used, although the stock one had a shorter glass bowl under it.
TD-9 Mark
01-18-2005 16:30:12
 Re: TD-9 in reply to Ron in Nebr, 01-17-2005 16:48:03
It does start on Gas, then runs on Deisel. I figured the water seperator from something else would work in a pinch, any suggestions?
Thanks, Mark
RAS
01-17-2005 14:47:19
Call Dresser at 731-635-6316 and they will help you find a dealer.
