Re: gas caps
Kevin
01-17-2005 16:13:04
Whats exactly wrong with the old one? I havent has problems with the one on my H yet. Also do these new ones look original or are they different?
schmidty
01-17-2005 19:01:08
 Re: gas caps in reply to Kevin, 01-17-2005 16:13:04
old ones aren't vented so tank becomes pressurized from agitation and heat. open tank with hot engine and fumes ignite. I believe the new caps are taller and marked "vented"?
Dr.Evil
01-18-2005 08:20:28
 Re: gas caps in reply to schmidty, 01-17-2005 19:01:08
Actually, the old caps were vented, but a quick quarter turn and the whole cap came off. The NEW safety cap is similar in design to a radiator cap as You need to turn it one-quarter of a turn, then lift the cap slightly to relieve the pressure "IF" the vent has plugged up, then You turn another quarter turn to remove the cap. It's also wize to extinguish all smoking materials while fueling any engine, and shut the engine off, and let it cool down for a bit. It always seemed ODD to Me that the low profile cap that IHC/Navistar is replacing on this program is/was an Industry Standard cap that ALL companies used.... and the taller triple-baffle cap was a Special IHC Only cap that prevented raw gas from possibly excaping from the cap vents....
