farmall m rebuild
tim bynum
01-17-2005 18:50:13
can anyone tell me if i can rebuild my m with out taking the block out of the tractor? any help will be appriciated. tim
captaink
01-19-2005 08:27:40
 Re: farmall m rebuild in reply to tim bynum, 01-17-2005 18:50:13
Here is my 2 cents worth.
It can be done, and has been done for up to 75 years on M’s. That being said there could be a lot of crud built up in the water passages in that block. I have seen and heard about many heads on M’s cracking, and I have a theory that I have bounced around as to why. My theory is that poor water circulation due to all those years and who knows what kind of water and anti-freeze mixes leaving behind (mostly in the back of the block) all kinds of muck etc. I recommend taking the block out, and to a good machine shop and get it cleaned thoroughly. After all everyone needs a good bath sooner or later to remove the goo! :>}
Jim Lockhart
01-17-2005 20:55:29
If it run and doesn't leak any fluids,restore the M with the motor in it,just my thoughts
Wayne Swenson
01-17-2005 19:31:52
Yes you can; I would invest in a good step stool to gain enough height to work on head bolts, valve adjustments, etc.
tim bynum
01-18-2005 05:33:16
 Re: farmall m rebuild in reply to Wayne Swenson, 01-17-2005 19:31:52
can the crank be pulled with the engine still in the tractor? thanks again, tim
JT
01-18-2005 06:56:02
 Re: farmall m rebuild in reply to tim bynum, 01-18-2005 05:33:16
NO, you would have to remove the engine from the tractor to remove crankshaft.
