400 Diesel Rear Engine Seal
Farmall Frank
01-18-2005 11:21:43
Do you have to drop the oil pan to replace the rear seal? If so, why?
Farmhand
01-18-2005 18:10:23
 Re: 400 Diesel Rear Engine Seal in reply to Farmall Frank, 01-18-2005 11:21:43
You will have to split the tractor to get to the rear main seal for it is behind the flywheel and it is no fun job.
Geoff NY
01-18-2005 16:37:57
The rear seal carrier is held in place by a part that is partly covered by the oil pan. The gaskets for the carrier will need replacing too. That carrier is behind the flywheel so it"s no simple job. Good luck..
