Adding ps to Farmall 504???
cjm in wi
01-18-2005 12:54:46
I am buying a 504 without power steering and I was wondering how hard and expensive it would be to add it now. any ideas are appreciated. thanks in advance. I look forward to learning a lot from this site and you folks.
BigDiesel
01-19-2005 04:49:57
 Re: Adding ps to Farmall 504??? in reply to cjm in wi, 01-18-2005 12:54:46
I have a farmall 504 that i am parting out, it has the add-on power steering. has the Charlynn orbit motor and a belt driven pump , reservoir and lines. sell it all for $500.
Sloroll
01-18-2005 13:31:58
Did that last winter! You need the oil cooler, lines to the pump, a handpump a different steering shaft from the knuckle closest to the steering wheel. There are some specialized lines to make with a check valve and Ts. Seems like it was arround $600 in used parts and a lot of bandaids or a torch. I got most of what I needed from Jeff Foreman in IN. I feel he treated me very well and he was great at walking me through the procedure.
