Found this tractor. What is it?
Cotton Picker
01-18-2005 16:32:52
While driving in Mississippi today I spotted a yellow looking tractor that looked like a W-6 or W-9.
It has dual wheels that look like road construction tread. The front wheels were tall with solid cast rims. It is a diesel that starts on gas.
Finally found the serial number plate, it read:
MRS Special Serial# IDCP 23712 Y
It was very hard to read the serial number, not sure if the C may be a 6(ID6 tractor), but it looked like a C.
What is this thing, it had five different levers on it besides the gear shift.
Is it worth anything?
Thanks for any help you can give
Harold H
01-19-2005 05:52:48
 MRS in reply to Cotton Picker, 01-18-2005 16:32:52
Mississippi Road Supply at Flora, Mississippi made MRS tractors during the letter series years (1940's-late 1950's) using IHC power trains as large as the UD-18 (same as TD-18 crawler). Most common size MRS during this era used the UD-14 engine. Most were used for scrapers or dirt wagons. Later models, built untill sometime in the 1970's were mostly four wheel drive units and were mostly sold to the Military along with farm and construction customers. A few years ago I had found some MRS specifications and information and posted them on this site but they have disappeared over time.
Harold H
Redrider
01-18-2005 20:02:44
 Re: Found this tractor. What is it? in reply to Cotton Picker, 01-18-2005 16:32:52
It is an ID6, these were industrial tractors. The chassie was basicly the same as a WD6 and they shared the same engine. They could be had with a type of dual rear wheel set up. The rear cast center for duals was a massive hub that mounted a tire with split rim on the inside and the same on the outside. Very heavy. They also had solid cast front wheels with neumatic tires. As I remember they had some type of slipper clutch. The slipper clutch ingaged real slow to get a very heavy load moving before they locked up. The most common use for the ID6 was air port duty.
TJG
01-18-2005 19:23:49
That wouldn't have been in Money by chance?
Cotton Picker
01-19-2005 05:25:29
 Re: Found this tractor. What is it? in reply to TJG, 01-18-2005 19:23:49
This one is in Quitman County.
Not many people around the Greenwood, Money area have your initials. Can think of only one. Ever been to Wildwood Gin?
PHDM
TJG
01-19-2005 19:32:51
 Re: Found this tractor. What is it? in reply to Cotton Picker, 01-19-2005 05:25:29
They've about got the new mote plant up. We're dealing with them on a press.
TJG
01-19-2005 19:29:40
How did ya'll do saturday Haynes? We still got the lil ol gin down at Quito.
Cotton Picker
01-20-2005 02:36:12
 Re: Found this tractor. What is it? in reply to TJG, 01-19-2005 19:29:40
Good crowd for the first time there, about 55 tractors. I had 2 first places and a fourth place.
Is there a MRS tractor around Money? The one in Belen is very rough.
How's your dad doing? Hope to see all of yu'all in Cleveland.
TJG
01-20-2005 04:36:10
 Re: Found this tractor. What is it? in reply to Cotton Picker, 01-20-2005 02:36:12
Dad doing well thanks. Never looked close at it, but it's a yellow W or WD-6 with duals. Been sitting there 25 years. Was ginning at Tunica, had an anniversery sat, oughtta make Cleveland though.
Cotton Picker
01-20-2005 05:21:19
 Re: Found this tractor. What is it? in reply to TJG, 01-20-2005 04:36:10
Glad to hear about your father, maybe I will check that tractor out.
FYI, just to let you and your brother know, I left the National Cotton Council and went to work for Delta Oil Mill.
Mitchissippi
01-18-2005 16:55:45
Sounds like a construction tractor from the old Mississippi Road Supply Company. I think they built a lot of IH's construction equipment under contract, back in the 50's and 60's. Wish I could tell you more. Cotton_Farmer over at Red Power has spoke of this.
You from Mississippi?
Mitch
TJG
01-18-2005 19:27:04
 Re: Found this tractor. What is it? in reply to Mitchissippi, 01-18-2005 16:55:45
Hey Mitch, somebodyelse got my handle here. Tom
Mitchissippi
01-18-2005 20:42:47
 Zat you Cotton_Farmer? in reply to TJG, 01-18-2005 19:27:04
You're Famous! Wondered if you'd found this site.
Cold in the Delta tonight?
Mitch
Mitchissippi
01-18-2005 17:03:18
 Here's a link in reply to Mitchissippi, 01-18-2005 16:55:45
Here's why I said what I said.
Mitch
TJG
01-19-2005 19:35:54
 Re: Here's a link in reply to Mitchissippi, 01-18-2005 17:03:18
Lurk around a bit Mitch. The MS boys are getting pretty well represented anymore.
