Farmall B Engine serial #
Dixieland
01-18-2005 19:35:23
I would like to know for sure where to find the engine serial number on this B Farmall. The only number I have found is at the top front left edge above the govener but I can't make out but 4 digits.
gene b
01-19-2005 02:58:48
 Re: Farmall B Engine serial # in reply to Dixieland, 01-18-2005 19:35:23
Rhe# should start with FAB -----
CNKS
01-18-2005 19:47:27
It would be on a machined surface in the area below the #1 spark plug. If you have the original seat base, the chassis serial is on a plate on the left inside seat support. Unless you have a very late model, the engine and chassis serials match, provided the engine is original. Both numbers were 3 or 4 digits until early 1940, when they hit 10000. If it is 4 digits you have a 1939 or 1940.
Dixieland
01-19-2005 03:12:47
 Re: Farmall B Engine serial # in reply to CNKS , 01-18-2005 19:47:27
The seat # is FAB 42635 and the # below spark plug # 1 is AB 4569. It looks like the engine is not original based on your info.
